Encoder Basics
frijoli
System Serial Number: none yet
Re: Encoder Basics
Post by frijoli » Mon Oct 16, 2017 9:07 am
Just for clarification any 5 v line drive optical encoder will work. Correct?
I am looking at the Automation direct 1/4 inch Solid Shaft Line Driver (TRDA-2E Series).
https://www.automationdirect.com/adc/Sh ... A-2E2500VD
This is for my lathe spindle motor.
They have open collector and line drive. I assume open collector is not what I want. (edit: I just saw the open collector is 12v)
Clay
Clay
Outside Winston-Salem, NC
Re: Encoder Basics
Post by cnckeith » Mon Oct 16, 2017 9:24 am
clay,
Hello.
http://www.automationdirect.com/pn/TRDA-2E2500VD
will work just fine with Acorn.
5 volt quadrature differential with A,A- B,B- Z,Z-
ScotY
Re: Encoder Basics
Post by ScotY » Sat Oct 21, 2017 12:57 am
Out of curiosity, can you use an absolute encoder? Or only incremental?
Re: Encoder Basics
Post by martyscncgarage » Wed Nov 01, 2017 10:59 am
INCREMENTAL, DIFFERENTIAL/LINE DRIVER OUTPUT ONLY, +5VDC input
I'm perplexed why guys keep fighting this.... :roll:
"Jack of all trades, master of none!"
WesM
Re: Encoder Basics
Post by WesM » Sat Nov 25, 2017 2:10 am
Has anyone tried the modular CUI encoders from digikey? Iv been looking over the data sheet and I cannot see any reason they should not work. I am looking at the AMT113Q-V model specifically. Sorry if this has already been asked, i googled around but did not see it brought up. It is incremental, differential, quadrature line driver with 5VDC input and can be set up to 4096 ppr.
https://www.digikey.com/product-detail/ ... ND/4835229
http://www.cui.com/product/resource/amt11-v.pdf
Re: Encoder Basics
Post by martyscncgarage » Sat Nov 25, 2017 9:15 am
Used as a spindle encoder?
I do t see any reason why they wouldn't work. I use them on servo motors on my Dyna DM4400 and they have been working fine with Logosol servo drives.
System Serial Number: 100505
Re: Encoder Basics
Post by tblough » Tue Nov 28, 2017 12:24 pm
I'm using them with an OAK conversion of a Hardinge TFB for manual handwheel inputs. P/N is AMT112Q-V. Just be careful on max RPM or you'll exceed the bandwidth of the encoder. IIRC it's 4000rpm for resolutions above 768 ppr.
These are basic encoders - just the disc and housing. This means that you need to provide the shaft supported with bearings and mounting provisions for the housing to hold the housing and shaft relative to each other while allowing only rotation.
bloomingtonmike
System Serial Number: 0916130849
Re: Encoder Basics
Post by bloomingtonmike » Sat Dec 23, 2017 2:43 am
I am new to encoding terminology. I found the below passage helpful in understanding CPR and PPR. CPR most commonly stands for Counts per Revolution, and refers to the number of quadrature decoded states that exist between the two outputs A and B. With both outputs A and B switching between high and low, there exists 2 bits of information represented as 4 distinct states. The term quadrature decoding describes the method of using both outputs A and B together to count each state change. This results in 4 times the amount of counts that exist for each pulse or period. Therefore, the CPR of an encoder is the encoder’s PPR multiplied by 4.
Mikie in Bloomington IL
Re: Encoder Basics
Post by tblough » Sat Dec 23, 2017 3:02 pm
Here's a good explanation of the differences between CPR, PPR, and LPR (w/pictures for the visual learners):
http://www.cui.com/blog/what-is-encoder-ppr-cpr-and-lpr
tl;dr:
PPR describes the number of high pulses an encoder will have on either of its square wave outputs A or B over a single revolution. Therefore, CPR(counts per rev) = 4*PPR(pulses per rev) = 4*LPR(lines per rev). Some manufacturers refer to CPR as cycles per rev in which their definition makes CPR = PPR which causes endless confusion.
bloomingtonmike
Re: Encoder Basics
Post by bloomingtonmike » Sat Dec 23, 2017 4:39 pm
Yes exactly where I read that. Thanks for posting link.
Who is online
Users browsing this forum: jason1098 and 3 guests
