I am unable to run any NC except the Center drill OP 910. The file size seems off on the others. I tried copy and paste NC to another new document no luck, same file size. I don't think it is a Acorn issue but thought I would try here too. Seems like 9101 should work.
Fusion file link if that helps. https://a360.co/48nQvCn
417 abnormal end of job
Re: 417 abnormal end of job
The problem is the program number.
"O9101" on line 2 of the program tells the Centroid control that the code which follows, until the next M99, are part of a subprogram that should be extracted and saved for later use (rather than being run immediately). Look up M98 and G65 in the operator's manual.
You should either use a program number that is not in the range 9100 - 9999; or you should name your file, e.g., "O9101.cnc", so that Centroid recognizes that it is already in place as a numbered program. Using a different program number will probably be simpler and more intuitive.
Note that you do not need to have a program number ("Onnnn" code) in your file at all. Centroid does not use program numbers for any purpose except to identify embedded subprograms.
Thanks, I figured out it was the number but wasn't sure why. The post processor puts those numbers in, I just changed to the date to help me. I went back to a smaller number and it worked.cncsnw wrote: ↑Mon Sep 11, 2023 3:02 pm The problem is the program number.
