Page 1 of 4
lathe spindle question
Posted: Thu Aug 24, 2023 10:54 am
by midy
When switching from auto spindle control to manual, the software sets spindle speed to zero (or very low) Is there a parameter to make it stay at 100% ? Small problem I know but would save pressing the button every time I switch.
cheers
Re: lathe spindle question
Posted: Thu Aug 24, 2023 11:53 pm
by cncsnw
That is a function of the PLC program.
Typical PLC logic is like this:
;--Adjust spindle override when entering manual or auto spin mode
;Set the override value to 100% when spin auto mode is first selected
IF SpinAutoManPD && !SpinAutoModeLED
  THEN SV_PLC_SPINDLE_KNOB = 100,
       SET SpinAutoModeLED
;Set the override value to 10% whenever manual mode is entered
IF SpinAutoManPD && SpinAutoModeLED
  THEN SV_PLC_SPINDLE_KNOB = 10, RST SpinAutoModeLED
As you can see, it sets the spindle override percentage to 10% on an auto-to-manual mode switch. This results in a speed that is 5% of the maximum RPM for the current spindle range (10% of half speed).
You can change that behavior to whatever you want, by changing the second SV_PLC_SPINDLE_KNOB assignment, saving your changes, and recompiling the PLC program.
Posted: Fri Sep 01, 2023 6:24 am
by midy
Ok, I think I get what to do but not sure where to find this piece of code to change it?
Posted: Fri Sep 01, 2023 5:45 pm
default is 50% of max RPM. this is a safety feature so spindle doesn't go to max rpm when you switch to manual.
what is your max rpm set to for this machine? post a fresh report.zip so we can see how you have things setup.
Posted: Wed Apr 30, 2025 10:41 am
by midy
cheers
I never did get this sorted
SET SpinAutoModeLED
Can somebody tell me what/how and where to do with this code please to get my solutuion?
Posted: Wed Apr 30, 2025 2:10 pm
by suntravel
You have to learn to work with the PLC, edit and compile....
Easy to implement the code from Marc if your NP++ is set up as recommended
Posted: Thu May 01, 2025 10:14 am
by midy
I guess it would help if I knew what the PLC is? Or how to find it?
Posted: Thu May 01, 2025 10:26 am
by suntravel
Related reading:
The file to edit is acorn_lathe_plc.src in the cnct folder
Posted: Thu May 01, 2025 10:31 am
by midy
Thanks, thats what i was after
Posted: Thu May 01, 2025 11:03 am
by midy
Oh, I'm not sure if re-compiling is above my pay grade. I've managed to make the change in the code though but not sure about compiling...hmm
