Hey folks,
Downloaded the new lathe 5.02 and there is a bug--on VCP LIMIT SWITCH DEFEAT brings to Intercon radius help screen. How to fix it?
Thanks, M
CNC 12 Acorn Lathe 5.02 Bug
Re: CNC 12 Acorn Lathe 5.02 Bug
thanks, confirmed! working on it now.
ok, easy fix. we were working on making things the same between Acorn and AcornSix and the Acorn limit defeat button got broken but its and easy fix.
open the limit defeat button XML file and change the skin even number from 67 to 25
<vcp_button>
<skin_event_num>25</skin_event_num>
<plc_output>
<number>1109</number>
<color_on>#EC1C24</color_on>
<color_off>#81151C</color_off>
</plc_output>
</vcp_button>
save the file.
restart cnc12
note this uses up Aux 14, so you can't use Aux 14 for anything else.
in v5.04 this will change and the limit defeat button will not use Aux 14 and Aux 14 will be free for other uses.
<vcp_button>
<plc_output>
</plc_output>
</vcp_button>
save the file.
restart cnc12
