error importing unlocks
kilo7
CNC Control System Serial Number: 74E182A80DDE-0312191753
Post by kilo7 »
Hello to this forum:
I have been trying to import digitizing (ultimate) license file
to a working version of 4.82 Mill pro. The result is Fail. error is
“ error importing unlocks” and changes MillPro to Free version.
I have done clean install of acorn v4.82 Milo Pro and it operates all axis’s as advertised. Bad Digitizing upgrade license ??? Im a a loss on this one.
A job worth doing “right", is!
Gary Campbell
Re: error importing unlocks
Post by Gary Campbell »
Any chance you did the license download on a Mac computer? Won't work, you need a pc
kilo7
Post by kilo7 »
Hi Gary, .
I down loaded direct from email. the license file from cnc4pc (Mill Pro to Ultimate) . Result is the same message “error importing unlocks” Mill Pro is working as advertised . I will upload a report at next opportunity.Thanks
kilo7 wrote: Wed Mar 08, 2023 11:45 am Hi Gary, .
upload a fresh report.zip AND the problem license file
kilo7
Post by kilo7 »
The importing of license file for Ultimate upgrade causes the software to revert to Free Version on restart of the software.
If setup as Mill Pro , No change it just keeps the Mill Pro Status.
No errors are indicated . All axis function . Using C86AACP , which is working as well.
report_0C1C57043D5E-0423203177_2023-03-12_23-47-34.zip
(778.87 KiB) Downloaded 8 times
license-0C1C57043D5E-0423203177-C139582-acorn-ultimate-mill.dat
changes Acorn back to free version on restart
(146 Bytes) Downloaded 7 times
Somehow, in your license*.dat file, all of the line endings have been changed from a carriage return and a line feed (standard for DOS/Windows) to two carriage returns and a line feed.
That is evidently causing problems for CNC12 when it tries to import the file, perhaps because the first (extra) carriage return is interpreted as a character at the end of the hex-codes sequence.
Centroid would do well to modify CNC12 so that, after it parses a "line" from the file, it strips any remaining leading or trailing white space characters (spaces, tabs, carriage returns, or newlines). That would reduce the number of support inquiries from people whose license files have moved through non-Windows file systems.
kilo7
Post by kilo7 »
The fix for this .dat file ?
i've asked diysales@centroidcnc.com to help you out.
Centroid_Liviu
Post by Centroid_Liviu »
We are emailing another License. Please download it directly to the PC being used to eliminate any issues. If you are still encountering issues please give me a call at 814-353-9290 ext. 117 and I can TeamViewer in to your computer and get this resolved.
