x-x+ jogging moves in the same direction in the x- direction <resovled>
jogging x- and x+ both moving in the same direction in the x- direction dro shows the correct -,+. y functions correctly z-z+ also move in same direction but z only moves in the + direction was working correctly previously without any wire or software changes
Re: x-x+ jogging moves in the same direction in the x- direction
this is on acorn controller
E415F6F70BC3-0318203049
Please generate and post a report.zip so we can see what's going on. Some hi-res photos of your control cabinet would also help
Hope this helps
Nigel
Nigel
this is the report.
- report_38D26950659D-0122180571_2023-01-23_16-04-22.zip
- (754.34 KiB) Downloaded 36 times
Looking at your report, this appears to be a new build?
Please look at this post and provide all the details about your build:
When the machine is running fine or as you are progressing, always create a fresh report. F7 Utilities, F7 Create report.
That way, if something gets changed you can always RESTORE from the working report.
Have/are you following the Acorn installation manual?
what kind of axis motors and drives? which schematic did you follow?mccue.sc wrote: ↑Mon Jan 23, 2023 12:43 pm jogging x- and x+ both moving in the same direction in the x- direction dro shows the correct -,+. y functions correctly z-z+ also move in same direction but z only moves in the + direction was working correctly previously without any wire or software changes
teknic clearpath motors and arcorn version 3 multiple clear paths
- S14885.r5.pdf
- (103.22 KiB) Downloaded 25 times
it is still in bench test mode all is just hooked to linear actuators all was working fine was about to hook up to mill when this problem arose will try to up load pictures tomorrow
Something changed.
Did you go into the Teknic software and make any changes?
Any wiring changes?
As Keith asked, which schematic are you using?
The DIR line goes logic high and logic low to command the drive to change directions. Put a DC meter, positive probe in it and the negative probe on COM. Watch the voltage go high and low as you change directions on the Virtual Control Panel
Make a little video of this test and lost it to YouTube as unlisted and post a link here
no changes was sitting for about a month before I could find the time to put on the mill was making a bulkhead for cables to pass thru the bottom of the cabinet. powered back up with the cables just thru the hole in the bottom power supply for the motors and ethernet cable for the acorn turned back on and x was acting up but will try and post video later tonight. attached the schematic that i followed and used the optional drive ok signal in blue on schematic.
- S14885.r5.pdf
- (103.22 KiB) Downloaded 28 times
