Hi Tom,
Thanks for the link, this is wary close what I am looking for to do
not for woodworking but for plastic pipe cutting and milling.
/PLData
The AcornSix CNC controller kit has been released!
Re: The AcornSix CNC controller kit has been released!
Adam made use of the Centroid APi and wrote his own UI to replace CNC12 (its just running in backgroud) he has strong prgramming skils!
he used microsoft visual studio and c# along with the Centroid APi to create the screens he needed for this project.
- CNC Control System Serial Number: many boards
Hi Keith,
ok, is there a better and easier way to get a PLC to control the CNC12 for automation ?
/PLData
/PLData
You could have your PLC create a g-code file and then set up a aux button on CNC12 to execute the g-code file.
HI,
How or where can I get the Centroid APi and description ?
/PLData
/PLData
basic documentation is included with every CNC12 installation.
look in the folder called "CncSkinningDocumentation" (soon to be renamed "Centroid Api")
in the cncm or cnct directory
AcornSix D-Scout Expansion board is now available. more info here.
https://centroidcncforum.com/viewtopic. ... 153#p86153
