Fuji servo drives with acorn.
Re: Fuji servo drives with acorn.
or roll your own.
https://centroidcncforum.com/viewtopic.php?f=60&t=2627
good news we will be adding the AcornSix Step and Direction Differential Quadrature Expansion board to the Centroid Ecommerce website (shopcentroidcnc.com) soon.
it is available for purchase now the Part Number is #15130 $199 if you want to call it in. 814-353-9256 press 2 for diy sales.
software for THC support is being tested now
Now Available.
https://shopcentroidcnc.com/shop/cnc-ex ... out-board/
The AcornSix D-Scout Interface board provides six drive axes of RS422 compatible differential drive output signals as well as 4 additional Scout RJ45 expansion ports. The D-Scout board is commonly used when AC servos drives are being employed with the AcornSix to make use of the superior quadrature step and direction signal communication protocol that the D-Scout board provides. The additional Scout ports facilitate easy connections with a common shielded Ethernet cable to any Centroid Scout communication protocol equipped product such as the PLCEXP1616 (#14575), Scout Operators Control Panel (#14612) and the Encoder-Scale Input board (#15330).
Plugs directly into the AcornSix motherboard.
