Shawn and Tom both answered the question very well. Nothing to add here!
Stepperonline CL86T with Acorn
Re: Stepperonline CL86T with Acorn
Didn't mean to steal your thunder Marty. I just wanted to point out that the 5V drive DOES still require a resistor if using 24 volts, it just doesn't need to be installed by the builder, it's inside the drive already.martyscncgarage wrote: ↑Fri May 12, 2023 11:08 am Shawn and Tom both answered the question very well. Nothing to add here!
No worries! I am taking a break from CNC and building Hot Rods...my hands are full.ShawnM wrote: ↑Fri May 12, 2023 12:16 pmDidn't mean to steal your thunder Marty. I just wanted to point out that the 5V drive DOES still require a resistor if using 24 volts, it just doesn't need to be installed by the builder, it's inside the drive already.martyscncgarage wrote: ↑Fri May 12, 2023 11:08 am Shawn and Tom both answered the question very well. Nothing to add here!
Thank you for continuing to be active on the forums Shawn/Tom!
No problem Marty. Send some pics of the Rods. I've always been in awe of the artistry you guys are capable of!
I was not implying the internal circuit did not need it, I was implying the user did not have to provide and wire it in.ShawnM wrote: ↑Fri May 12, 2023 10:51 amThey do still require the resistor it's just built into V4 and you select 5 or 24 with a DIP switch. The DIP switch is putting the internal resistor inline with your 24 volt input if you choose 24 volts. If you wire it up with 5V then you are in essence taking the resistor out of the equation when you flip the DIP switch to 5V. These are still 5v drives.
Greg
Pics, Manuals. Specs, Datasheets for build - https://drive.google.com/drive/folders/ ... share_link
CNC12 Mill Pro
All in one CNCPC
Ether1616 Expansion Kit
Centroid Wireless MPG
2 Relay 8 Boards
Stepperonline 3Nm Closed Loop - CT57T Driver
Stepperonline 12Nm Closed Loop - CT86T Driver
Omron Encoder
DIG3D.LP.M Touch Probe
DIG3D.Fix Touch Off
Signal Isolator
CNC12 Mill Pro
All in one CNCPC
2 Relay 8 Boards
Omron Encoder
DIG3D.Fix Touch Off
Signal Isolator
Awesome, enjoy and have a great weekend.martyscncgarage wrote: ↑Fri May 12, 2023 12:18 pm No worries! I am taking a break from CNC and building Hot Rods...my hands are full.
