Posted: Wed Jan 17, 2024 3:52 pm
but i suppose that is not to switch to the new 0-100% rapid override function ?
My OCD is apparently slightly stronger than yours as I redesigned EVERY button on the VCP. The OEM buttons us various size fonts and some look bold where others dont. I couldn't take it any longer and made all new ones and added a boarder around each one. All use Arial font and all fonts are the same size. I sleep a lot better now.brittfussel wrote: ↑Tue Jan 23, 2024 1:27 pm My OCD is strong on this one but not so strong to redesign all the buttons. But I could get there. Thank you for your assistance.
Britt
I resemble that remark. And, some have square corners, where others are rounded. That seems to be some radiused rectangle issue though. If you open them in Inkscape, select them, and use the rectangle tool, one corner RX or RY is set to 0.0. Edit to match the radius for both and they're fixed.
Thanks Scott, I tried to forget that part but now the nightmare is back. There goes my good nights sleep.Sword wrote: ↑Tue Jan 23, 2024 3:57 pmI resemble that remark. And, some have square corners, where others are rounded. That seems to be some radiused rectangle issue though. If you open them in Inkscape, select them, and use the rectangle tool, one corner RX or RY is set to 0.0. Edit to match the radius for both and they're fixed.
Best I can tell is: Franklin Gothic Demi Condbrittfussel wrote: ↑Tue Jan 23, 2024 1:27 pm I have been able to successfully write a macro and design my own button for the VCP. I've also been able to successfully modify the VCP to use my new button design and activate my macro. I was able to replicate the color used by Centroid for the VCP buttons, but I do not know the font that is used. Since the fonts are blown apart into paths, I cannot determine the font. Can someone tell me the font that Centroid uses for the buttons for the latest version of the Centroid 12 software? I tried searching on the keyword font in this thread and the keywords VCP font in the Acorn discussion but did not find anything. I did notice a post that might suggest that Centroid designed their own font? I did notice a post comment that someone redesigned all their buttons to use the same font. My OCD is strong on this one but not so strong to redesign all the buttons. But I could get there. Thank you for your assistance.
Britt
RonnieWRonnieW wrote: ↑Tue Mar 05, 2024 12:29 pmBest I can tell is: Franklin Gothic Demi Condbrittfussel wrote: ↑Tue Jan 23, 2024 1:27 pm I have been able to successfully write a macro and design my own button for the VCP. I've also been able to successfully modify the VCP to use my new button design and activate my macro. I was able to replicate the color used by Centroid for the VCP buttons, but I do not know the font that is used. Since the fonts are blown apart into paths, I cannot determine the font. Can someone tell me the font that Centroid uses for the buttons for the latest version of the Centroid 12 software? I tried searching on the keyword font in this thread and the keywords VCP font in the Acorn discussion but did not find anything. I did notice a post that might suggest that Centroid designed their own font? I did notice a post comment that someone redesigned all their buttons to use the same font. My OCD is strong on this one but not so strong to redesign all the buttons. But I could get there. Thank you for your assistance.
Britt
I just used an online Font Finder and uploaded a screenshot from the manual. That could get you close and then might have to tweak kerning of fonts in an illustration program.
