Page 25 of 29
Posted: Thu Nov 30, 2023 5:36 pm
agsweeney1972 wrote: ↑Thu Feb 16, 2023 3:57 pm
I am just gonna leave this here...
Full post is coming.
full post is here.
https://centroidcncforum.com/viewtopic.php?f=57&t=9469
Posted: Thu Nov 30, 2023 10:53 pm
by ste6168
Maybe I am stupid, but I cannot for the life of me figure out how to change the default VCP. I would like to start with the router VCP, then modify from there. Currently am using the mill. I have looked through both manuals, surely I am overlooking something?
Posted: Thu Nov 30, 2023 11:45 pm
by tblough
You might want to start at the beginning of this thread. Third post has a link to the manual and every other post has usable info.
Posted: Fri Dec 01, 2023 1:22 pm
by ShawnM
If you bought a mill license then the install will load the mill VCP. You cannot install the router version VCP with a mill license. That said the software is EXACTLY the same but a different VCP is installed depending on your license.
The OEM VCP (mill or router) can be fully customized to make the mill version look just like the router version or anything you like, you just need to swap the buttons around. All the buttons for all versions are installed in the buttons folder on you pc. All info for doing this is in the VCP manual found here.
Posted: Thu Dec 14, 2023 7:29 pm
ste6168 wrote: ↑Thu Nov 30, 2023 10:53 pm
all acorn documentation is here.
https://centroidcncforum.com/viewtopic.php?f=60&t=3397
there you will find the VCP editing manual and related macro manual.
Posted: Mon Dec 18, 2023 5:50 pm
by guitarchitect
I haven't even gotten my unit out of the box but I'm excited about the VCP potential!
One thing I can't find information on - if I have my monitor in "portrait" mode is it possible to set the control matrix at the top or bottom of the screen? I could only get a 22" resistive touchscreen monitor, and it's probably a bit on the wide side. I like the idea of having the controls on the bottom for easy access, with the diagram/cutting paths at eye level!
Posted: Mon Dec 18, 2023 6:05 pm
by tblough
Portrait mode is "possible" -
https://centroidcncforum.com/viewtopic. ... 176#p56176
More here -
https://centroidcncforum.com/viewtopic.php?p=7558#p7558 from 4-years ago where Centroid states they might consider it but it is easier said than done.
Posted: Fri Jan 05, 2024 6:43 pm
kicked the can down the road to the "screen set builder" project.. then you can do anything you want.
Posted: Tue Jan 09, 2024 12:01 am
fyi... an updated VCP users manual is now available.
I added 10 pages to the VCP manual to bring it up to spec with the v5.08 VCP feature set and edited many of the existing pages as well.
comments and suggestions for improvement are welcome
be sure to refresh your browser to see the latest with today's date (1-8-24).
Posted: Tue Jan 09, 2024 3:28 pm
Draft status of the new VCP users manual has been lifted.
refresh your browser to download the latest version with 1-9-24 date
