I had a problem with Wifi signal in my garage. Turns out you can buy signal boosters. Here is the one I purchased from Target for $29. It seems to work just fine and now I can run Team Viewer over the WiFi in my garage.
https://www.tp-link.com/us/products/det ... 860RE.html
The booster can "clone" the name of your main router. That didn't work for me - I had to give it it's own name and then everything worked just fine.
-Franco
WIFI Signal Booster
Re: WIFI Signal Booster
cool thanks for the info.. this will come in handy.. you don't know how many times i've tried to teamviewer into a system with terrible wifi connection..now there is no excuse to have a solid signal to the cncpc! thanks franco!. k
I bought a similar one off of Amazon. They work really good. Gives me much better coverage on that side of the house and if set up properly the phone will change between the 2 as it moves in the house. Great deal.
Son in law is IT professional, eats and sleeps this stuff. When I was visiting over Christmas he showed me how his "Mesh Network" operates. Good strong signal everywhere and totally seamless. Also not all that expensive. Sold by Google, Amazon, Cisco, etc.
His setup was by Google and worked perfectly.
The range extenders I have used in the past have a delay to them that gets annoying at times.
