cnc 4 to acorn wiring
camaro4025
CNC Control System Serial Number: cnc4-md3-10-80v serial#1872
Post by camaro4025 »
Hey guys received my acorn board today, have a question about wiring from micro1 input header to acorn ? Does pulse go to step , dir to dr , pwr to com , cpugnd to en. If not let me know the right wiring diagram. Thanks
Centroid_Tech
Re: cnc 4 to acorn wiring
Post by Centroid_Tech »
The connections would be below.
MICRO1 --> ACORN
PULSE --> ST
DIR --> DR
PWR --> EN
CPUVCC --> +5V
CPUGND --> COM
Remember that since those terminals on the ACORN are open-collector, you are going to want a pull-up resistor installed between those ACORN outputs and +5V. I would recommend either a 330 ohm resistor.
camaro4025
Thanks again.
Centroid_Tech2
Post by Centroid_Tech2 »
Here is the schematic for Acorn to Micro1 drive.
S14910-ACORN_rev3, CENTROID CNC4 MICRO1 DRIVE.pdf
(91.7 KiB) Downloaded 132 times
