Been using the Acorn with clearpath servos all working well, the only issue I have is that I can't get the Z axis to rapid move.
In the wizard the maximum speed seems set to 150, is this correct? I am engraving 800 parts and the z axis speed is slowing the cycle down. Can the Z axis speed be increased?
Thanks.
Acorn Z axis feed rate too slow
Re: Acorn Z axis feed rate too slow
