Sorry, I realise thatMuzzer wrote: ↑Fri Mar 30, 2018 9:13 am The Renishaw probe is unpluggable, since it is on an ISO40 holder. If you unplug it, Acorn knows, you get an error message and the probing won't work. The tool setter is hard wired in.
I'm in a rush to leave for the weekend but the key settings seem to be:
#43 is 2 (set Zref with TT, use #44 for input)
#44 is 7 (Renishaw input, open on contact)
#11 is -4 (TT input, open on contact)
#17 is 3 (go to position G30 P3 for fixed TT)
#18 is 6 (Renishaw probe detect, spindle inhibit)
#257 is -6 (check for TT present, spindle and tool measurement inhibit)
I think those are the ones that matter. As noted, this is a normally closed tool setter that opens when tripped, so the signal on input 4 is now "NC". The variables 18 and 257 are different signs but this is what works(!). I'm pretty sure there's something not right around #257 anyway....
#44 should be described as "TT input, open on contact"
#11 should be described as "Renishaw input, open on contact".
Connections were right but my descriptions were mixed up.
