Code Syntax Help Please
Gary Campbell
Post by Gary Campbell »
I am looking to make a minor change to my tool measure macro. (attached)
I am looking to set variable #105 (line 16) to parm [#9071] (tt1 height) for use when on the spoilboard. That parm is used on line 148
This will be used for tool numbers 1 thru 20.
Can be seen at 3:16 into this video: https://youtu.be/xqTpEXHOWPw
When using the rotary, with tool numbers 21-30 I need an "IF / Then" statement similar to: IF tool# > 20 Then #105 = {fixed number}
This number will be set and hard coded into file once rotary is in place
Are there any examples that I can look at?
mfunc6FixedToolTouchOff.mac
(9.65 KiB) Downloaded 113 times
diycncscott
Re: Code Syntax Help Please
Post by diycncscott »
Hi Gary,
That macro is comprised almost entirely of IF/THEN
If I understand you correctly:
#105 = user variable - note: #100-#149 are reset to 0 after every job. They should only be used in macros that initialize their value explicitly.
#4120 = system variable used to store requested tool from g code
IF #4120 < 21 THEN #105 = #9071
IF #4120 >= 21 THEN #105 = 1.2345
Does that answer your question? Maybe you were looking for an "ELSE" (I generally prefer not to use them as I find the second IF more obvious that it is explicitly applied to only tools >= 21)
IF #4120 < 21 THEN #105 = #9071 ELSE #105 = 1.2345
Gary Campbell
That did it! You are the man!
Thank you
Gary Campbell
OK, I have another one that has me stumped. I am writing a short macro to set Parm 71 to the distance between the spoilboard and tool measure switch height. All works well, except I cant get the G10 line that writes the parm to accept my "R" value, which is a variable. I have tried seting user variable 105 to system var 5043, tried using #5043 as the "R" parameter... tried with and without every combo of square brackets, but I keep getting either error 704 Invalid parm or 501 invalid character. What am I missing?
Clip of macro here:
M115 /Z P[#104] F[#102] ;Move at fast probing rate until TT1 detected
M116 /Z P-[#104] F[#103] ;Retract at slow probing rate until TT1 clears
M115 /Z P[#104]F[#103] ;Move at slow probing rate until TT1 detected
#105 = #5043 ; Sets #105 to Current Z position
G4 P1
G10 P71 R#105 ; Writes Switch height to Parm
G4 P1 ;Wait 1 second
G53 Z0
M225 #101 "#)**SWITCH HEIGHT SET**\nPress Cycle Start to continue"
N1000 ;End of Macro
diycncscott
Not all parameters are writable and not all parameters will store a floating pt. value. P71 is Read-Only. P181 is an old baud rate parameter that is no longer used. It is writable and will store a floating pt. number.
BTW - P14 is already used as a "fast probe rate" (read using #9014), slow probe rate is p15(read using #9015). Neither is writable however.
You can also read the probe input directly with either #5000# where # = plc input number or #9011 if p11 is set to the value of your probe plc input
M115 /z p#50007 F#9014
or M115 /x p#9011 F#9014
Gary Campbell
Thanks Scott...
Trying to write to a read only makes sense... now.
I'm setting the speeds in this file faster than normal for probing and intentionally not using the stored values. I do use them with the touch plate
Still wont work.
If I enter G10 P181 R[#5043] into the mdi the variable is written properly no matter where the z is positioned. When the macro is run p181 is written as 1.2000 any ideas on what I have screwed up now?
mfunc71.mac
(2.3 KiB) Downloaded 93 times
report_9884E39427E5-1206170338_2018-02-21_14-25-45.zip
(170.42 KiB) Downloaded 87 times
diycncscott
Try wrapping it in IF #50001 to prevent look ahead from setting value prematurely
Works fine for me. Also, make sure #5043 is a positive number (Z axis position). No such thing as a tool post with a negative height
IF #50001
G10 P181 R#5043
IF #50001
Gary Campbell
I think I found it.
Did the "wrap' with #50001 worked, then it didn't
It appeaars that if the value (z pos) is less than 1 (maybe 1.20) it sets the parm as 1.2000
My spoilboard will always be lower, so it should not return an error in normal operation
Does parm 181 have any restriction (input masks)? 1.2k baud rate? Shades of Prodigy :lol:
Thanks for your time. Life is good
diycncscott
Sorry, use p251 no floor, no ceiling within reason. writable. positive, negative....
Gary Campbell
Got it, thanks
