Acorn Step/Dir Differential line driver
jmaks
CNC Control System Serial Number: E8EB11292335-0206180631
Post by jmaks »
I have the yaskawa SGDS servopacks, and the drive will only accept line driver step/dir, Is there a way i can interface them to the Acorn?
thanks
Gary Campbell
Re: Acorn Step/Dir Differential line driver
Post by Gary Campbell »
Since the board terminals are open collector output, I would suggest using the DB25 step & direction terminals
jmaks
Post by jmaks »
Thank you Gary, i didn't realize the DB25 was 5 Volt, i will be using the DB25 with this https://cnc4pc.com/differential-line-driver.html, my Acorn is arriving tomorrow i will post how it works out.
jmaks
Post by jmaks »
It works just fine, thank you
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
I also use the DB25 signals for Step/Direction outputs and open collector outputs for Drive Enable, etc. I ended up milling a little PC board and just soldered the differential driver ICs. Works perfect.
Russ
