TB6600 Drivers
Posted: Thu Feb 08, 2018 7:50 pm
Hello
I have 3 CNC Single Axis 4A TB6600 2/4 Phase Hybrid Stepper Motor Drivers Controller now these drivers need +5vdc to the pulse and direction terminals of each drive and on the Acorn I connect the Step and Direction connection to the Pulse and Direction on the TB 6600 boards. Now the Enable is High for the Stepper Driver to active the motor if Enable is brought low the Drives free Wheel. Now the Common for the TB6600 needs to be 5 vdc plus so does the Acorn board have to have a 5vdc supply connected to "Common" and to 24 Vdc Common.
Also I have AN 8MM X 1MM LEAD AND PITCH so how do I configure the axis? IN THE ACORN SETUP, THEY ARE DIRECT DRIVE SO NO RATIO AND THE drivers ARE SET AT 4 giving me a 800 STEP/REV
Am I close or should I start again ?
