Reposting Previous Problem - Limit Tripped
Ukie
System Serial Number: "38D2693E3856-0111180526"
Post by Ukie » Tue Feb 06, 2018 10:44 am
Can a previous post be reactivated and if so, how. I previously submitted a problem that I was having with my Acorn board and was not able to get it to work as suggested, so I went back to my post with a followup question a few days ago and have not heard back from anyone. It also looks like my previous post has been closed.
diycncscott
Re: Reposting Previous Problem
Post by diycncscott » Tue Feb 06, 2018 11:12 am
If the control is reporting a limit tripped, it means that you have defined an input as a limit and the input/switch is open, it is unrelated to your stepper drive. Press alt-i from the main screen to bring up the real-time I/O display. The top row are the inputs with input 1 being on the far left. Use the arrow keys on your keyboard to move the box around each input and look in the bottom center of the screen to see the label. All inputs assigned as a limit MUST be green or the control will report a limit tripped.
If your limit switches are normally closed (closed when a limit is NOT tripped), the input should be set to NC, if they are normally open (closed when the limit IS tripped) they should be set to NO. You can change the NO/NC setting in the Wizard.
Ukie
Re: Reposting Previous Problem - Limit Tripped
Post by Ukie » Tue Feb 06, 2018 12:22 pm
I was able to clear the tripped limit switch problem but now I am getting error "9031 Drive Fault" and not sure why this is happening.
diycncscott
Post by diycncscott » Tue Feb 06, 2018 1:53 pm
You have an input defined as DriveOk and it is not closed.
cncman172
System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 » Tue Feb 06, 2018 8:12 pm
As Scott suggested the first thing to do is use the wizard and remove the drive ready assignment. Then examine my post on drive ready signals. Let me know if you have questions
Russ
Who is online
Users browsing this forum: AcornFanBoy, Chaz, heathmanc and 2 guests
