woffler wrote: ↑Fri Jan 19, 2018 3:39 pm
I have a question on input 2 with a DYN2 drive, wiring says ZRI or absolute zero position index ,what do you set it to in the Wizard?
When i selected Dmm Tech it set it to 2nd limit.
You do NOT set anything up in the Wizard.
Are you planning on using the ZRI for homing?
What kind of machine are you working on? Lathe, Mill?
The theory is (mill),
You series all your limit switches together, one lead goes to common, the other goes to input 1. Select HOME ALL in the Wizard.
You set input 2, 3, 4 to UNUSED in the Wizard.
You connect the ZRI from X to input 2, Y to input 3, Z to input 4
The software still sees the inputs. Its simply watchig for the state to change on the input, when it does, it stops and sets that axis to home.
Credit goes to Scott Pratt, the
Great Wizard at Centroid for working with me to coming up with the home file:
There is a custom cncm.HOM file you have to make up for example:
M92 /Z L1 ;Move to Z+ limit switch, back off until it clears.
M105 /Z P-4 F1 ;Move Z minus at 1ipm until input 4 closes
M26 /Z ;Set Z home here
M91 /Y L1 ;Move to Y- limit switch, back off until it clears.
M106 /Y P-3 F1 ;Move Y plus at 1ipm until input 3 closes
M26 /Y ;Set Y home here
M91 /X L1 ;Move to X- limit switch, back off until it clears.
M106 /X P-2 F1 ;Move X plus at 1ipm until input 2 closes
M26 /X ;Set X home here
Save a copy of the .hom file to another directory because if you run the Wizard after creating it, it WILL overwrite it with the default .hom file
I just posted a video today demonstrating using the DYN4 and the above .hom file
I have previously posted one for the DYN2. The info is buried here in a post. Search DMM DYN2 or DYN2
(YouTube: martyscncgarage)
