Hi from down under (Australia) I purchased two Acorn boards in November to up date my emco PC 5 Lathe and small mill.
I planed to buy all the hardware and bench test the boards before i purchased the pro license for mill and lathe. As it tuned out
I decided to buy two rev 3 boards with pro mill and pro lathe licenses in December , one spare and one for a bigger lathe project.
When the new Acorns arrived I found that the licenses are linked to the new boards so I set them up on the bench to test them.
This is where I have the problem I work out which license went with which acorn and tried to load the license to each board
the mill license loaded but the lathe pro license will not load. I have tied every thing I can think of but still known go so here i am.
Just need a little help.
I have Attached a report I think
Graeme
Acorn will not load pro license
Re: Acorn will not load pro license
thanks for the report. we will email you a fresh license file in a bit.
A new license has been emailed to gppat_____@i____e.__.net
There was a typo when the original was generated.
I apologize for the inconvenience.
- CNC Control System Serial Number: 38D2693D963F-1222170398
Thanks Keith and Scott for the quick response, I thought the numbers did not match .
I haven't received the new license email yet.
Scott know need to apologise I understand how busy the centroid team must be.
Unlocks were sent yesterday 8 jan 2018 12pm EST.
Check your pm and/or check you spam
