Can you use Acorn with multi-core processors
I am wondering if the ACORN Controller can function with Multi-Core Processors. My question is due to having a I3 computer and wanting to use it instead of buying a new computer. I presently use Mach3 and found it works great with multi-core processors.
Re: Can you use Acorn with multi-core processors
Check your single thread speed here: https://www.cpubenchmark.net/singleThread.html
There should be no reason multi-core won't work unless it isn't fast enough, or your computer doesn't meet the rest of the stated requirements on the Centroid CNC page here: http://www.centroidcnc.com/cnc_pc_perfo ... ments.html
Clay
near Winston-Salem, NC
yes multi core PC CPU is no problem, we run I3,I5 and I7 all the time.
just make sure one of those cores benchmarks around the minimum speed requirements.
