I just bought an acorn and the pro version software...
want to say thanks to Marty's Garage watching his videos sold me...
I currently use mach 3 on my router I need to use a .tap
file for mach to read, I was wondering what output file type is
needed for the Centroid acorn system.
thank you,
Charlie
what type of output file is needed
Re: what type of output file is needed
Acorn CNC12 reads G&M codes. G&M code files are simply text files.
Acorn CNC12 doesn't care about the extension of the file, it could be .txt, .nc, .cnc, .tap , .dig etc, etc..
Press F2 Load, navigate to file, click open... and then Graph the file with F8 Graph. if it graphs, it runs.
- CNC Control System Serial Number: 38D2693D0BD1-0105180478MPU12
Keith,
thanks for the info,
I will give it a try and see what happens once I have it set up.
Charlie
Charlie
