Does anyone have any info on the correct settings for connecting a 120V E-trac VFD to the Acorn.
The 0-10V speed control is working, I can vary the speed, but the FWD/REV is not. The reset/fault etc likewise must be configured. There are 3 'PS' lines that are configurable. The polarity of the active logic is also configurable.
E-Trac VFD to Acorn
Re: E-Trac VFD to Acorn
Would be very helpful if you can post a .pdf of the manual so we can look through it with you....cgpre67 wrote: ↑Thu Jan 04, 2018 5:52 pm Does anyone have any info on the correct settings for connecting a 120V E-trac VFD to the Acorn.
- CNC Control System Serial Number: BOD5CC470093-1205170316
Hi Marty,
The unit we have is a E-Trac XFC1001-0b; Input 115V, 8.9Amp 1HP Outputx 3.5-230V @4 Amps.
I finally found a .PDF for you.
Best Regards
Best Regards
- TB-Woods-XFC-Series-datasheet1-177469416.pdf
- (392.88 KiB) Downloaded 81 times
