Genovation USB Keypad
I've had this keypad for a while now & decided to start the new year off getting it working. It's not an X-Keys but seems to do the same job a bit cheaper. https://www.amazon.com/gp/product/B00O1 ... UTF8&psc=1 I paid $72.95 but noticed they've recently gone up some. I struggled with some self-induced software issues for a while today but finally got it working well. The Centroid button labels on the website are for a mill so I had to print some lathe specific labels. I used TurboCAD & they came out OK.
Milton in Collierville, TN
Re: Genovation USB Keypad
Nice, you have more patience than me.. i played with the Genovation unit and gave up!:-))
thanks for posting.
is there a config file you can share?
thanks for posting.
I have had pretty good luck with the Genovation on other controls. Usually the hardest thing is to get the arrow keys to work right.
Profile attached ".txt" added for the forum, remove when DL
Let me add, that I was going to try this keypad on my lathe. I can set it up and post a profile, if needed
- GC CNC Keypad.ckd.txt
- (3.97 KiB) Downloaded 113 times
I had a lot of trouble with the arrow keys as well & was amazed at the wierd things that happened when they were pressed.
Thanks to Google I found a post on a router forum that mentioned the fix was simple as changing the 'Mode' from "Default (Auto Sense)" to "Separate Up Codes" & making sure the "This macro can auto-repeat" box is checked. Once I changed all 24 keys to that setting, everything smoothed right out. I haven't decided on the final key choices or their locations yet but feel pretty confident I can set things up just like I want. Oh yeah, the other thing I had difficulty with (although it's explained clearly in the .pdf manual) is that once the keys are programmed, you press 'Download' & those settings are loaded into the keyboard over USB. After that it's good to go when the Wiz has been setup for USB & CNC12 is running. I really like it so far but it's f-f-f-fuh-freezing out in the shop right now and further testing will have to wait. I can confirm that it does work & responds very quickly to tap-tap-tap on the arrow jog buttons. The big double key STOP! button I set up works quick too!
I like the big double stop button!
