Nothing is connected. My screen shows 1000 rpm when in manual and I have 5 volts on the analog out. The off button doesn't change anything.
When I switch to auto it drops to zero rpm, and voltage goes to zero. If I do an MDI I can change the speed/voltage.
What am I missing?
Clay
Bench testing. Spindle won't turn off(resolved)
Clay
near Winston-Salem, NC
Re: Bench testing. Spindle won't turn off
Please post a report so we can the config settings.
Okay. I thought this was going to be an easy one.
- report_985DAD4295AE-1005170145_2017-12-29_19-39-50.zip
- (173.27 KiB) Downloaded 112 times
Clay
Please run the wizard and select benchtest radio button on tab #1 and then write settings.
You have a single output defined as SpinRev, this is not a standard benchtest setup:
OUTPUT1 IS OUT1 ;&*;
OUTPUT2 IS OUT2 ;&*;
SpinREV IS OUT3 ;&*;
OUTPUT4 IS OUT4 ;&*;
OUTPUT5 IS OUT5 ;&*;
OUTPUT6 IS OUT6 ;&*;
OUTPUT7 IS OUT7 ;&*;
OUTPUT8 IS OUT8 ;&*;
Are you connected to a G540?
I have nothing connected.
I attached 3 reports
One at minimum speed in manual, one at max, and one in auto
- report_985DAD4295AE-1005170145_2017-12-29_20-05-01.zip
- (173.37 KiB) Downloaded 102 times
- report_985DAD4295AE-1005170145_2017-12-29_20-05-20.zip
- (173.39 KiB) Downloaded 123 times
- report_985DAD4295AE-1005170145_2017-12-29_20-05-32.zip
- (173.41 KiB) Downloaded 108 times
Clay
Benchtest is meant to test communications only.
To test spindle analog out, select a config with a SpinFwd/SpinRev out. Try G540 drive only. Change EstopOk to NO
With nothing connected, I'd suggest max 1000rpm, min 0rpm.
Gear ranges all 1
You need to have the spindle enabled (SpinFwd or SpinRev on) to measure analog out.
Spin override 100%
Select "Auto" spindle mode (LED on) Use MDI
M3 S250 = VDC Voltage?
M3 S500 = VDC Voltage?
M3 S750 = VDC Voltage?
M3 S1000 = VDC Voltage?
Do NOT exit MDI
Gear ranges all 1
Spin override 100%
Do NOT exit MDI
I was trying to see if I could test the spindle reverse output. That's it.diycncscott wrote: ↑Fri Dec 29, 2017 9:27 pm Benchtest is meant to test communications only.
Gear ranges all 1
Spin override 100%
Do NOT exit MDI
I'm not trying to test anything else yet.
What I am asking is, Why does the spindle speed on the screen say 1000rpm when it's supposed to be off?
And it won't turn off. That's what is concerning me.
Clay
Maybe I phrased the question incorrectly.
With everything disconnected in bench test mode should this be what I see? And there is voltage on the analog out.
Clay
See it now, press alt-i to display real-time I/O
