I have Windows 10 Home. I don’t know if there are different versions of this OS but my system setting says it’s a 64 bit operating system x64 processor.
As an update, CNC12 has been working well with no issues. I still don’t know the cause of my earlier problems. I have not yet tried to swap out the memory cards but will when I have some free time.
CNC12 unresponsive and ethernet communication error (check firewall)
Re: CNC12 unresponsive and ethernet communication error (check firewall)
ScotY,
Did you figure out what was wrong. I just checked your CPU and it is clearly fast enough on single thread rating. This should work on that PC.
Russ
Intel Pentium G4600 @ 3.60GHz
Average CPU Mark
Description: Intel HD Graphics 630
Socket: FCLGA1151
Clockspeed: 3.6 GHz
No of Cores: 2 (2 logical cores per physical)
Typical TDP: 51 W
Other names: Intel(R) Pentium(R) CPU G4600 @ 3.60GHz
CPU First Seen on Charts: Q1 2017
CPUmark/$Price: 54.25 Overall Rank: 614
Last Price Change: $94.83 USD (2017-01-11)
5144
Single Thread Rating: 2056
Samples: 205*
*Margin for error: Low
Russ
Average CPU Mark
Socket: FCLGA1151
Clockspeed: 3.6 GHz
Typical TDP: 51 W
5144
Samples: 205*
Hi Russ,
No, still haven’t found the source of the problem. I had two 4GB memory cards in the PC. I removed one card, thinking I had a bad one, and then the problems went away. I plan to swap cards and see if I can make the problem come back. Would be nice to know. I will definitely post if/when I have a solid answer.
