Wiring Teco FM50-202-C
I have the Teco Westinghouse VFD
http://dealerselectric.com/images/Produ ... manual.pdf
I have figured out the Reset, For, Rev, Reset pins and figured out how to program them. Where the confusion coming in is that pin 5 is 12v. So I'm hopeful someone will take a look at the manual that I linked to above and to let me know which pin to hook to as the common (I think pin 10) and which pins to hook up the the 0-10v analog ground and out H8 (I think is is pin 10 for ground and pin 9 for the analog output). If that is correct, it is ok to have 2 leads going to pin 10.
The wiring diagram is on page 19.
Thanks in advance
Thanks in advance
Re: Wiring Teco FM50-202-C
Did you get your VFD wired up? I am not so sure the FM50 can be used on ACORN.KirkD wrote: ↑Thu Dec 21, 2017 9:28 pm I have the Teco Westinghouse VFD
Thanks in advance
martyscncgarage wrote: ↑Sat Dec 23, 2017 8:21 pmDid you get your VFD wired up? I am not so sure the FM50 can be used on ACORN because it appears that its inputs need a voltage SOURCED to them.KirkD wrote: ↑Thu Dec 21, 2017 9:28 pm I have the Teco Westinghouse VFD
Thanks in advance
I would be curious if taking a wire from pin 10 and touching FWD withOUT a 12 or 24VDC power supply to see if it will turn the VFD on.
IF NOT
I could see making it work by using the 6channel relay board I showed in another video. The mechanical relays would be controlled by Acorn, the relays are the switches from 12VDC supplied by the VFD to FWD and REV. Does this make sense to you? You would have one relay for FWD, one relay for REV and one for RST (reset) but it should be doable.
No Marty, I have not even tried. I didn’t want to fry the vid or the acorn board
It does take 0-10VDC input, move the jumper.
I would take a jumper from COM (PIN 10, not 12V) and touch to FWD and see if the VFD turns on the motor.
If not, you will have to use NO relays (6channel relay board with 24VDC coils) and use those contacts to supply the 12V to the FWD and REV inputs of the VFD. I think its doable. What size VFD and what kind of spindle are you trying to control.
2hp w a 2hp lesson motor on a mill.
I was looking a voltage converters|
https://rover.ebay.com/rover/0/0/0?mpre ... 2365124189
I think I follow you Marty. My tri-power supply has 12v already on it.
Is this the item you are referring to?
https://rover.ebay.com/rover/0/0/0?mpre ... 1489871547
Yes. It will allow ACORN outputs to drive 6 more dry contact relays beside the two that are on board.KirkD wrote: ↑Sun Dec 24, 2017 12:50 am I think I follow you Marty. My tri-power supply has 12v already on it.
You feed +24VDC to the Com+ terminal (picture is wrong in the ad) then from 1-6 wire to Acorn outputs 3-8
You would then use the 12V FROM the VFD to the Common of one relay and then the NO would go to FWD of that same relay. The a second relay in similar manner for REV and anothe relay for Reset (per Acorn schematics output 4+fwd, output 5= rev, output 6=reset)
I can chicken scratch up a schematic if needed? Or better yet, you draw it up and post it and let us take a peek at it.
Sorry for the delay. Shot a short video showing what I did. What donyou think??
https://youtu.be/3sn6YPa6jd0
Looks good. You are using Acorn outputs to drive dry contacts on relays that control the VFD inputs. Have you tested it yet?KirkD wrote: ↑Mon Jan 15, 2018 2:06 pm Sorry for the delay. Shot a short video showing what I did. What donyou think??
Reminder to move the SW1 to position 2-3 for the 0-10VDC analog input.
