Contactors? Best reasonably priced
frijoli
Post by frijoli »
I am ordering components for my panel. I need 50A magnetic contactors according to DMM. Can that be correct for a 1kW drive?? Seems really high.
Where is the best place to buy these at reasonable prices?
Clay
near Winston-Salem, NC
DICKEYBIRD
Re: Contactors? Best reasonably priced
Post by DICKEYBIRD »
Wow :o That C8's gonna twist itself into knots! All three axes cranking out 1 1/3 HP...at the same time? I think their contactor rating is for a much bigger machine. Check your PM in a few minutes.
Milton in Collierville, TN
frijoli
Post by frijoli »
That's what I need to clarify DMM. The drive has a rating of 8 amps. They say in the manual to add 50A contact rating for each drive. That means I need 150A contactor!!! Something seems very wrong. lol
I am going to follow up with DMM Monday.
Clay
Clay
lilb93
CNC Control System Serial Number: 0216041209
Post by lilb93 »
I just got in my 3 DYN4 drives saturday and no where in the manual do I see it needs contactors. Just a e-stop to knock out the 24V
Barnesville, PA.
I always thought it would take longer to grow old.
frijoli
Post by frijoli »
lilb93 wrote: Sun Dec 17, 2017 4:17 pm I just got in my 3 DYN4 drives saturday and no where in the manual do I see it needs contactors. Just a e-stop to knock out the 24V
Did it come with a manual? I used the download manual.
Clay
jason1098
Post by jason1098 »
This threw me for a loop as well... Here's what I found when i was having the same problem:
If you look on page 23 of the manual, you'll see the notes that say:
3. Select circuit breaker (MCCB)
and magnetic contactor (MC1) with
enough capacity according to servo
drives connected.
So I take that to mean if each drive pulls 8.3A, you can use a 30A magnetic contactor... but that's how I read it. I'm still learning the high voltage wiring myself. I'd love to hear other's input about my assumption.
frijoli
Post by frijoli »
jason1098 wrote: Sat Jan 13, 2018 11:52 am
drives connected.
Thanks, I didn't see that in the manual, but I went with what actually made sense to me, and purchased a 32amp contactor and some 30amp fuses.
Clay
Clay
I'm using something like this to power up the whole cabinet on the Phoenix 4x4 router:
2 Pole 30A 120V Definite Purpose Contactor Honeywell DP2030B5004 http://r.ebay.com/ixVmzy
This would be a good choice for the relay to Estop the power to the DYN4 drives. I'm not so sure I am worried about the logic supply side. No 240VAC to DYN4's= no servo motor movement.
These are good because they are 24VDC coils, you can run 24VDC through relay 1 (Estop relay) and then to the relay below (Or use a non relay output):
DAYTON 30A Enclosed Power RELAY Contactor 24 VDC 1EJH9 (12) http://r.ebay.com/XwmFJf
(These are what I am using to turn off and on the router motor and the dust collector)
The math:
750W servo, assuming 240VAC input:
750/240= 3.125A per servo motor
3.125A*3= 9.375A and that's, shall we say, balls out.
The relays above are DPST. They have 2 sets of contacts and they are normally open. Contact rating should be WAY more than enough for the 3 DYN4 drives running at 240VAC input.
I finished my backpanel, opened up my servo drive box and found 400W NEMA 23's instead of 750W NEMA 34's. I emailed DMM, hopefully they can ship the correct motors on Monday....it happens.
ScotY
Post by ScotY »
I don’t really understand how the MCCB and MC1 are wired up in that diagram. I know how a relay works but the diagram makes no sense to me. Can someone explain? I’ll need to do something for my single Dyn4 when I get around to wiring it up.
frijoli
Post by frijoli »
ScotY wrote: Tue Jan 16, 2018 2:49 am I don’t really understand how the MCCB and MC1 are wired up in that diagram. I know how a relay works but the diagram makes no sense to me. Can someone explain?
Below is a single phase 110 or 220 input at R/S. MCCB is a circuit breaker. I used fuses.
The branch has estop, the Master Control 1 coil, and on/off switch.
MC1 coil makes R/S come on when the circuit is closed.
R/S goes to the motor power.
L1, L2 branch off to the logic supply of the drive. Hence the EMI filter and low Ampere fuses.
Clay
