Acorn 3d model
frijoli
Acorn 3d model
Post by frijoli »
Mostly to scale. All mounting holes are accurate.
Terminal location are are spaced proper distance apart, however they are probably only within .02" as they are measured from the board.
I had to use a USB connector instead of an Ethernet, but you know what it is.
Clay
Clay
near Winston-Salem, NC
francoCNC
CNC Control System Serial Number: B0D5CC39D321-0822170083
Re: Acorn 3d model
Post by francoCNC »
Nice. Fusion360? Are you sharing the file? If so, I know a few guys (myself included) that would like that.
-Franco
frijoli
Re: Acorn 3d model
Post by frijoli »
francoCNC wrote: Fri Jan 26, 2018 12:18 am Nice. Fusion360? Are you sharing the file? If so, I know a few guys (myself included) that would like that.
-Franco
Yes Fusion 360.
There are two versions out there. Mine isn't perfect, but I can share it. The terminals are in the correct location, mounting is correct, but the Ethernet port is not an ethernet port, but USB.
I am traveling today, so it will be tomorrow before I can do it.
Clay
Clay
frijoli
Re: Acorn 3d model
Post by frijoli »
-Franco
See if this works. Never shared from Fusion before.
http://a360.co/2DDv3KD
Clay
MarysMakeShop
Re: Acorn 3d model
Post by MarysMakeShop »
Hey guys. I was interested in 3D printing a case for my Acorn so I made a 3D model of version 3(Acorn 171025). Pictures are below here is the link to download the file in the extension of your choice: https://a360.co/2pBMQMq
The difference between board versions, at least physically, seems to be the terminal strips(they protrude more). Mine isn't as pretty as frijoli's(AcornBoardV2), but the file is 10x less memory and I was able to design an enclosure without any loading problems. Sometime my PC struggles if the board has too much detail. Anyway, thought I would share it in case it would help someone. It was made in Fusion 360 and I designed a 3D printed case around it and it fit(3D printer resolution= 150 microns). I'll be uploading the video and files to my 3D printed case soon!
Update 3/24/18 : I updated the 3D model to adjust the mounting holes and DB 9 location, had to clean it up a bit. Link is the updated version! Stay safe out there!
Last edited by MarysMakeShop on Sat Mar 24, 2018 12:13 pm, edited 1 time in total.
dudeTheory
Re: Acorn 3d model
Post by dudeTheory »
lol it looks like everyone is doing the same thing.
here's pic of the one i made, mounting points were accurate enough to make a case.
I 3d printed a prototype case, I'll be making a final version out of acrylic.
PLData
CNC Control System Serial Number: many boards
Re: Acorn 3d model
Post by PLData »
Hi,
Fine work, but be careful not to close the acorn card in so it can not get it cooling and burm off !!
\PLData
MarysMakeShop
Re: Acorn 3d model
New downloadable case for Centroid Acorn. Link to download the case: https://www.thingiverse.com/thing:2872967
Miguel G. and I collaborated to make a 3D printed case for my version 3(Acorn 171025) Centroid Acorn. This case is compatible with Acorn 171025 and later. It's made in fusion 360. I've uploaded to my thingiverse the .f3d, .step and .stl file so you can change and adapt it to fit your needs!
https://youtu.be/WaK6ZS0Xnnw
