As requested from another thread. Phoenix COMBICON DFK-MSTB series connectors. I purchase them from Digikey, but they should be handled by your favorite electro-supplier. To see the whole line, I enter the series name in the search bar (in red) and in most cases the complete line is returned.
These are 10A panel mount connectors and plugs. Plugs have screw fasteners into the blocks. The blocks have solder terminals to the rear, the plugs have screw terminals for connecting wires. There are higher wattage versions (some with rear screw terminals) if needed. Here are the Digikey part numbers I use:
Here is the catalog page showing the panel mount terminal block:
Here is what they look like on the panel I make:
And a view from the back:
Phoenix Bulkhead Connectors
Re: Phoenix Bulkhead Connectors
Thanks Gary!
