DMM AC servo spindle and C axis. Parts ordered!
Dale Powell
CNC Control System Serial Number: 38D2697C7838-0522180924
Re: DMM AC servo spindle and C axis. Parts ordered!
Post by Dale Powell »
New here, how to hook up the dny4 to the new relay board. Drawing 500863 shows hooking to the acorn Oc5 , and what 2k resistor, can the acorn controller dive the spindle and be a c axis. Really won't to know how.
Dale Powell wrote: Fri Feb 01, 2019 7:10 pm New here, how to hook up the dny4 to the new relay board. Drawing 500863 shows hooking to the acorn Oc5 , and what 2k resistor, can the acorn controller dive the spindle and be a c axis. Really won't to know how.
Theoretically DYN4 can be driven as a C axis and a spindle. I am currently working on that now. However, there is SPECIAL firmware for the DYN4 that needs to do this. Did you communicate your application and desire to DMM?
I've done a video on the relay board.
https://youtu.be/_1nxIqcrhLY
ScotY
Post by ScotY »
So has DMM finally got a means to use the Dyn4 to drive a spindle without the weird behavior I was seeing a while back? I emailed them many a time and never got a response. Finally gave up on using it for my spindle drive. It worked but just not right.
ScotY wrote: Fri Feb 01, 2019 8:44 pm So has DMM finally got a means to use the Dyn4 to drive a spindle without the weird behavior I was seeing a while back? I emailed them many a time and never got a response. Finally gave up on using it for my spindle drive. It worked but just not right.
Theoretically yes. I'll be testing in the next several weeks
Dale Powell
One more time, I need help, how do I hook up Dny4 to the acorn board when using as a spindle drive. Drawing # 500863 shows hooking straight to the acorn board at H5 oc5 , I have a relay board , so if I hook dir+ (pin 22) to the relay board that oc5 operates, there is there terminals nc,c,no ok do I put the wire form from the dyn4 pin 22 to no, and put 24volts on the middle terminal. I have 20 email with Dmm and they didn't answer me what I need to know. Is this correct, what wattage resistor of a 2K .
Dale Powell wrote: Fri Feb 01, 2019 8:52 pm One more time, I need help, how do I hook up Dny4 to the acorn board when using as a spindle drive. Drawing # 500863 shows hooking straight to the acorn board at H5 oc5 , I have a relay board , so if I hook dir+ (pin 22) to the relay board that oc5 operates, there is there terminals nc,c,no ok do I put the wire form from the dyn4 pin 22 to no, and put 24volts on the middle terminal. I have 20 email with Dmm and they didn't answer me what I need to know. Is this correct, what wattage resistor of a 2K .
See attached
DYN4AcornSpindle_R2.pdf
(63.06 KiB) Downloaded 139 times
Dale Powell
Thank you, I just down load yesterday and I asked if there was a new rev for the relay board, now I have the wiring, when I go to buy the 2k resistor the are asking for wattage.?
Dale Powell wrote: Fri Feb 01, 2019 9:19 pm Thank you, I just down load yesterday and I asked if there was a new rev for the relay board, now I have the wiring, when I go to buy the 2k resistor the are asking for wattage.?
If you use the 5vdc power supply you can forgo the resistor.
