frijoli
Posts: 595 Joined: Tue Sep 12, 2017 10:03 pm
Post
by frijoli » Sun Nov 26, 2017 2:41 pm
I loaded a 6kb file and Acorn lathe pro is telling me I need to upgrade because the file is over 4mg.
It may be something in the post process but I can't imagine where.
Report attached if it's useful.
EDIT: I cannot even run the sample files that are over 5kb, provided by Centroid. These are the samples that come on the zip file for the software download.
diycncscott wrote:
I was able to re-create your issue. I have emailed you a new license to: cferriola@tri__.__.com
If you need it sent to a different email address, please send me an email at support@centroidcnc.com
report_985DAD4295AE-1005170145_2017-11-26_13-33-55.zip
(168.14 KiB) Downloaded 124 times
frijoli
Post
by frijoli » Sun Nov 26, 2017 9:51 pm
I have run into a few hurdles.
1. The program size is a bug. This is the sample program from Centroid and it is 7kb. I have pro software running, but every file over 5kb fails to load.
2. The program error message 417 does nothing to help troubleshoot the gcode.. lol
frijoli on Sun Nov 26, 2017 9:58 pm, edited 1 time in total.
diycncscott
Post
by diycncscott » Mon Nov 27, 2017 10:27 am
Hello,
Please try re-importing the license.dat file from scratch as shown below.
1. Please delete c:\cnct\license.dat
2. Download the attached file:
3. Rename the downloaded file to: license-scott-985DAD4295AE-1005170145-pro-lathe.dat (remove the .txt from the end of the name)
4. Go back into F7-Utility->F8-Options->F2-Import License and select the file downloaded above.
frijoli
Post
by frijoli » Mon Nov 27, 2017 10:53 pm
Thanks Scott!
I'll have to do it tomorrow... Long day.
frijoli
Post
by frijoli » Tue Nov 28, 2017 8:35 pm
diycncscott wrote: ↑ Mon Nov 27, 2017 10:27 am
Hello,
2. Download the attached file: license-scott-985DAD4295AE-1005170145-pro-lathe.dat.txt
No go...
report_985DAD4295AE-1005170145_2017-11-28_19-07-56.zip
(169.07 KiB) Downloaded 106 times
frijoli
Post
by frijoli » Tue Nov 28, 2017 8:36 pm
Hello,
No go...
(169.07 KiB) Downloaded 100 times
diycncscott
Post
by diycncscott » Wed Nov 29, 2017 10:08 am
I was able to re-create your issue. I have emailed you a new license that solves the issue to: cferriola@tri__.__.com
