6040 Chinese routers
lilb93
CNC Control System Serial Number: 0216041209
Post by lilb93 »
Wondering if anyone has converted a 6040 router there all Chinese there 4 axis. All of them run on a pirated mach 3. They sell anywhere between 1500.00 to 1800.00
Barnesville, PA.
I always thought it would take longer to grow old.
Re: 6040 Chinese routers
we have two different 3020T's in house.
lilb93
Post by lilb93 »
Is it easy to convert to Acorn?
Barnesville, PA.
trival. up and running in minutes. make sure you get the controller with the db25 connector.
see attached.
centroid_acorn_cnc_controller_3020T_web.pdf
(852.04 KiB) Downloaded 133 times
lilb93
Post by lilb93 »
Photo looks the same except my controller is USB no db25. and the VFD is a card not an actual VFD. It was a craigslist buy I got
He never even turned it on.
Barnesville, PA.
sometimes you can open the drive box and remove the usb breakout board and run the stepper drivers directly with acorn board header connections.
lilb93
Post by lilb93 »
Will post some photos of the box opened, Maybe you can tell me what I need.
Is the Lathe ready to go YET.. LOL
Barnesville, PA.
lilb93
Post by lilb93 »
Photos 1st one is the side of one of the driver boards there are 4 of them in the box. 2nd one is the USB board.
Barnesville, PA.
lilb93
Post by lilb93 »
more photos the 1st , 2nd , and third is there VFD on a card? the last one is the power supply output
Barnesville, PA.
lilb93
Post by lilb93 »
first one shows the 4 drivers and the power supply hidden under the VFD board. Last one is there VFD board. I have no manual with it or wiring schematics.
Barnesville, PA.
