6040 Chinese routers
- CNC Control System Serial Number: 0216041209
Wondering if anyone has converted a 6040 router there all Chinese there 4 axis. All of them run on a pirated mach 3. They sell anywhere between 1500.00 to 1800.00
Barnesville, PA.
Re: 6040 Chinese routers
we have two different 3020T's in house.
Is it easy to convert to Acorn?
Barnesville, PA.
trival. up and running in minutes. make sure you get the controller with the db25 connector.
see attached.
see attached.
- centroid_acorn_cnc_controller_3020T_web.pdf
- (852.04 KiB) Downloaded 133 times
Photo looks the same except my controller is USB no db25. and the VFD is a card not an actual VFD. It was a craigslist buy I got
He never even turned it on.
Barnesville, PA.
sometimes you can open the drive box and remove the usb breakout board and run the stepper drivers directly with acorn board header connections.
Will post some photos of the box opened, Maybe you can tell me what I need.
Is the Lathe ready to go YET.. LOL
Barnesville, PA.
Photos 1st one is the side of one of the driver boards there are 4 of them in the box. 2nd one is the USB board.
Barnesville, PA.
more photos the 1st , 2nd , and third is there VFD on a card? the last one is the power supply output
Barnesville, PA.
first one shows the 4 drivers and the power supply hidden under the VFD board. Last one is there VFD board. I have no manual with it or wiring schematics.
Barnesville, PA.
