DM-3000 Lathe Acorn conversion
DICKEYBIRD
Re: DM-3000 Lathe Acorn conversion
Post by DICKEYBIRD »
Oops, I was going by the pictures on his photo link. My bad!
Milton in Collierville, TN
No biggie. Just another her way to take care of it. Actually more straight forward. But you are correct, have to use the signal isolator on KB drives. The issue is with reversing them.
kaimaui
Post by kaimaui »
Just finished wiring acorn to automation direct GS2 spindle drive.
Followed the centroid provided documentation. worked great.
Just order a Breaking resistor of bay for $18.00 so i can get faster deceleration.
https://www.ebay.com/itm/Aluminum-House ... 2749.l2649
All the way at the bottom of the album
https://photos.app.goo.gl/foisQ42QZEbmA4Nv1
KAI
Fastest1
Post by Fastest1 »
Out of curiosity, did you have the original encoder? If so, was there an issue interfacing with it?
I do have the entire assembly for mine and would like to use it if possible.
1st Acorn project. G0704/BDTools/Hoss Conversion De"maching"
Leadshine MX 3660
Repurposed above Acorn (#194) and an Ethernet 1616 to a UMC-10 with an 8 position tool changer.
CNC12 Pro/Digitizing ver 4.64 (1/31/2022)
Fastest1 wrote: Thu Nov 30, 2017 11:51 pm Out of curiosity, did you have the original encoder? If so, was there an issue interfacing with it?
For the spindle? Junk it. Buy the one that Kai used. 2000 line industrial encoder, just turn down the end of the shaft for it. (Its also the one on my DM3000)
Its only $65!
I think this is it:
https://www.automationdirect.com/adc/Sh ... D-SH2000VD
kaimaui
Post by kaimaui »
I took some photos of how i reduced the shank on the mill.
Db-9 screw terminal plug from ebay.
https://www.ebay.com/itm/DB9-Male-Screw ... 2749.l2649
kaimaui
Post by kaimaui »
Shars starter kit.
This is what i ordered from shars to get started.
https://photos.app.goo.gl/gziCeYxIwriCQBb53
temp shars.pdf
(302.68 KiB) Downloaded 147 times
