Finally got time to start the Acorn installation into my Techno-Isel router and here are some photo of the progress to date:
Here is the original controller and the mounting area after it was removed:
After removing the original controller I designed the Acorn mounting using Alibre Design:
Here is where I'm at now and I'll probably finish the wiring this evening and start testing tomorrow.
Techno-Isel Router Acorn Upgrade
- CNC Control System Serial Number: B0D5CC56DD75-0605170063 , 985DAD4295CF-0928170127 , 38D2694E4703-1222170401
Re: Techno-Isel Router Acorn Upgrade
Looks great!
Are you going to use the original power supply for the motors?
Clay
near Winston-Salem, NC
No
The large power supply in the photo is a Mean Well LRS-350-24 that will supply 24 VDC for the stepper motors. The smaller supply is a Mean Well RD-35B which will supply 24 VDC for the ACORN logic and 5 VDC for the stepper driver control.
What was the large toroidal supply in the early photo?
Clay
The power supply that was originally supplied with the router.
Was that toroidal power supply not suitable to reuse? What kind of voltages did it provide?
I like them over switchers if they can do the job.
Looking good so far. I'd like to buy/build a router/plasma table...some day!
Was that toroidal power supply not suitable to reuse? Not a simple re-use - Would have to be completely modified as a lot of the electronics were on the main controllers circuit board. Because of the value of the Isel controller it was a better decision to leave it intact and list it on eBay.
What kind of voltages did it provide? 24 VDC
I like them over switchers if they can do the job. Switchers work fine for low current motors.
very nice, thanks for posting..looking forward to seeing video of the machine in action.
