Hi All,
For those of you with an Acorn board- just wondering which post-processor, if any, people are using for fusion 360?
Should I use the centroid post processor Version: 41601? at
https://cam.autodesk.com/posts/
or a generic Fanuc post?
Any help is appreciated.
Daniel
Fusion 360 Post processsor for centroid acorn? (resolved)
- CNC Control System Serial Number: A900460
Re: Fusion 360 Post processsor for centroid acorn?
I am running the Centroid post and I'm having no problems with it.
dan
dan
- CNC Control System Serial Number: B0D5CCFC8F3C-0126170013
The centroid post processor on fusion 360 work perfect, ive been testing it with the acorn for over 6 months without a problem.
Alan
Alan
- CNC Control System Serial Number: 10583
Re: Fusion 360 Post processsor for centroid acorn? (resolved)
Has anyone used / developed a Fusion 360 post that will support multiple tool orientation (3+1 or 3+2 machining)?
I have been using the Centroid post that is available, however it does not support tool orientation. Before diving into the world of post development and comparing it to the Mastercam Post I have, I figured I would ask here.
John
EDIT: I realized this is in the acorn forum. I am using a CNC10 based control, however I will leave it here as it should be relevant to all.
John
For MILLING use the Centroid post. My 3 axis mill has no issues with it.DanielCA92563 wrote: ↑Fri Oct 13, 2017 1:34 am Hi All,
Daniel
There is a beta out for the lathe on this forum, but has yet to be thoroughly tested.
Clay
Clay
near Winston-Salem, NC
