Please get a video of this Franco!
encoder suitability
Re: encoder suitability
Clay
near Winston-Salem, NC
- CNC Control System Serial Number: B0D5CC39D321-0822170083
Here is the first video:
https://youtu.be/lXQky3xWHg8
Seems to be working OK so far. We'll see how well it holds up.
Great video(s) Franco, thanks so much for taking the time to produce & post them. You make it so easy to understand!
ps: Is it possible with Acorn to sync the Z-axis to the spindle with it (the spindle) turned back & forth by hand? To me, that is THE most graphic portrayal of encoder feedback.
Milton in Collierville, TN
That would be awesome. Imagine a MDI with the spindle on and zero speed would work?DICKEYBIRD wrote: ↑Sun Nov 26, 2017 9:57 am Great video(s) Franco, thanks so much for taking the time to produce & post them. You make it so easy to understand!
Franco doesn't mess around does he?
Clay
Clay
(Insert dope-slap smilie here)I should've thought of that! Then I could've been the first non LinuxCNC DIY-guy to post a video of that! Oh wait, I don't have a decent video camera yet.frijoli wrote: ↑Sun Nov 26, 2017 11:06 amThat would be awesome. Imagine a MDI with the spindle on and zero speed would work?DICKEYBIRD wrote: ↑Sun Nov 26, 2017 9:57 am Great video(s) ps: Is it possible with Acorn to sync the Z-axis to the spindle with it (the spindle) turned back & forth by hand? To me, that is THE most graphic portrayal of encoder feedback.
...and no, Franco don't play around! (Like me )
https://youtu.be/CKylcAPv1Tc
Check out 3:30 into this video.
Cool...thanks for posting that. If anyone does the same, you’ll have to swap wires on the encoder or the rotation will be backwards due to the use of gears.
Good point.
You can also change the sign (positive or negative) for the number of encoder pulses in the CNC wizard.
Encoders are cool...
Cool, I didn’t know that. I guess I can rewire my encoder the “proper” way and fix it in the Wizard.
Hey Guys - I'm getting closer to having that Mini-Lathe encoder mounting kit ready.
https://youtu.be/60GgctDS79E
