Great news!cnckeith wrote: ↑Tue Apr 30, 2024 3:02 pmit in the works.lavrgs wrote: ↑Sat Apr 27, 2024 7:17 pm Maybe Centroid could find and promote a $200 touch probe. I have a couple of the drewtronic probes and just checked it to my ring gauge to within 0.0005. It's not particularly fragile - i've broken a stylus and dialed it back in. I'd guess they must be a small company because when you call them you talk to a human without a phone tree
Video Walkthrough of How I Use the Acorn
Re: Video Walkthrough of How I Use the Acorn
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
cool use of digitizing by Uwe
and another cool use of centroid digitizing by Uwe.
Uwe is from a Galaxy far far away from ours. He ain't human! His brain is the size of a beach ball.
- Hickory CNC Controller: Yes
You could use the generic china one for like 80USD that most people use in te DIY atmosphere.
Due to the technology used, they pretty much all perform the same.
lobing anyone?
here is the one i got - 200$ wireless:
Error is probably within 0.005mm, and can reach the nominal accuracy within 0.01mm (after calibration).
As far as I'm aware only Renishaw does something fancy by adding strain gauges in the probe.
The 80$ wired 3d probes perform around the same, repeatably around <0.02mm after calibration. For the hobby sphere plenty good.
This chart was supplied with the probe I guess?
I have used some types of probes in the <200€ range and made probemaps with them.
Non was as good as a KP3, but maybe ok for hobby.
But for me, the most annoying thing was that none of the cheap probes stayed in center for a longer time and some of them were not so easy to adjust back to center.
KP3 is much stiffer, stays in center perfect, and you can use a very long stylus if needed.
Also, the contacts are oil filled on the KP3, on cheap ones not.
- CNC Control System Serial Number: A901313
Edingcnc have no radius compensation for mill.
and since Mr. Eding sold his products and his company, the software has gone downhill.
I think you had a Sorotec touch probe Uwe? 400€ How does it compare to the KP-3?suntravel wrote: ↑Wed May 08, 2024 3:45 am This chart was supplied with the probe I guess?
