I am currently bench building my control system and I am curious if there is a way to have one of the output relays to mirror the heartbeat to an external light? My intent is to have my Acorn in a closed box under the mill and I will not know if there is a heartbeat without opening the box.
Thanks!
Remote heartbeat
- CNC Control System Serial Number: 544538015759-012647917
- CNC Control System Serial Number: 0008DC111213-1005220061
Re: Remote heartbeat
very good question, would be also interessted for me. same issue here.
Some in the past have used fiber optic light guides to reposition the heartbeat.
you'll find once you get the machine configured and running you never look at the heartbeat again.
Thanks much, I figured I was overthinking it.
