Acorn won't run g code/mdi < lathe G98/G99?>
It jogs, runs the spindle(although the encoder doesn't match the s code), but it won't perform a program. I get a random communications error. I'm running the supplied shielded ethernet cable from Centroid.
Re: Acorn won't run g code/mdi
Instead of a copy of your license file, try posting a current Report file from your control. Use F7/Utility -> F7/Report to create one. The file name will begin with "report_", and it will have a ".zip" file extension on it.
That is what I meant to send...
- report_0479B7F04C20-0204202937_2024-04-20_14-19-04.zip
- (878.35 KiB) Downloaded 6 times
Have a look at your error log, it is littered with communication errors, this is why it wont run a file. You MUST fix this issue first before you can proceed. Read this document below, until you fix this issue nothing will work correctly. Did you run the com stress test? There's no way it would pass this test until the issue is corrected.
https://www.centroidcnc.com/dealersuppo ... ds/270.pdf
probably trying to command a G1 with an encoder installed
read up on G98 and G99 in the operator manual
but who knows i left my crystal ball at home.
Re: Acorn won't run g code/mdi < lathe G98/G99?>
I'm thankful...TRULY, for all the handholding. I wish I understood things better.. I took another, perfectly running Acorn PC and god the same results. Here's an image..I knows it a mess, but I'm trying to work with what I have...
latest report... I really hope someday to be able to help someone else out....
- report_0479B7F04C20-0204202937_2024-05-04_13-09-14.zip
- (846 KiB) Downloaded 4 times
Where is the ethernet cable?
The last 2 codes get movement, it doesn't like the g above it
