Acorn won't run g code/mdi < lathe G98/G99?>
Re: Acorn won't run g code/mdi < lathe G98/G99?>
Have you tried G98, as Keith suggested?
For example:
... or, if you are going to use G1 in the default G99 mode, do you have the spindle running already, and have you given it a suitable per-revolution feedrate?
For example:
For example:
G1 G98 F5 X1 Z1
For example:
M3 S1200
G1 G99 F0.01 X1 Z-2
I'll try that. My buddy has a bunch of old code from an AHA that he really just wants to transfer over and have work..cncsnw wrote: ↑Sat May 04, 2024 11:18 pm Have you tried G98, as Keith suggested?
For example:... or, if you are going to use G1 in the default G99 mode, do you have the spindle running already, and have you given it a suitable per-revolution feedrate?Code: Select all
G1 G98 F5 X1 Z1
For example:Code: Select all
M3 S1200 G1 G99 F0.01 X1 Z-2
Here is an example of the code he wants to run
I suggest to install current 5.1 software with the updates for a better Network connection on some hardware.
Your reports are 5.08...
.... are the com errors gone now ?
His Ahha programs will not run without some changes.
G90 is not appropriate there. All X and Z coordinates are absolute by default.
"F8" looks like an inches-per-minute feedrate. To use that, you need a G98 code.
