GS2 VFD problem
GS2 VFD problem
I swear, I wired it up EXACTLY like the GS20 schematic says...yes, I know it's obsolete. It worked...kind of, by forcing(before I followed the schematics) the relays..it never worked with the VCP. Everything I seem to do turns to poison...
- report_0479B7F04C20-0204202937_2024-04-18_19-07-21.zip
- (894.45 KiB) Downloaded 5 times
Re: GS2 VFD problem
The report shows that VFDEnable and VFDDirection outputs are forced off.
Re: GS2 VFD problem
Forced off? How?
Re: GS2 VFD problem
review the plc diagnostic menu instructions, sounds like you forced them off and didn't put them back to normal state.
Re: GS2 VFD problem
Re: GS2 VFD problem
13:49 output forced on off explanation.
Re: GS2 VFD problem
That was exactly the problem...thank you. NOW, while I can jog both axis and get the spindle running, it won't run any lines... I get a communications error IIRC.
- license-B4107B74F575-1115237688-C18039-acorn-pro-lathe.dat
- (139 Bytes) Downloaded 1 time
Re: GS2 VFD problem
And the encoder feedback for the spindle doesn't match the S command rpm...
Re: GS2 VFD problem
you have to calibrate the vfd to match the commanded.pescadoman wrote: ↑Sun Apr 21, 2024 3:04 pm And the encoder feedback for the spindle doesn't match the S command rpm...
