Page 3 of 3
Re: Screw Terminals vs DB25 Header
Posted: Sat Mar 02, 2019 12:56 pm
by tkbot47
Out of curiosity, where is parameter 968 and the table for it's values documented? I can't find it in the manual.
Posted: Sat Mar 02, 2019 1:05 pm
tkbot47 wrote: ↑Sat Mar 02, 2019 12:56 pm
viewtopic.php?f=60&t=2211&p=15784&hilit=968#p15784
Posted: Sat Mar 02, 2019 2:25 pm
by tkbot47
Marty, thanks! So, in other words it's kinda undocumented? In the manual, params 900-999 are listed as PLC Program Parameters. BTW, is the same param and setting valid for Mill Pro?
Posted: Sat Mar 02, 2019 5:25 pm
Yes.
It's undocumented, use at your own risk. Anything above 400k requires good wiring practice and a drive that accepts a pulse train over 400k
Posted: Sat Mar 02, 2019 5:55 pm
by Commotion
With so many being recommended to use 100k centroid probably should add that to the 200 and 400kHz options in the wizard.
Posted: Sat Mar 02, 2019 6:35 pm
by Gary Campbell
Its already in the next version
