Emco compact 8 Acorn Conversion progress
frijoli
Re: Emco compact 8 Acorn Conversion progress
Post by frijoli »
DMM servos on DYN4 drives. First motion!
https://www.facebook.com/clay.ferriola/ ... 916328393/
I used this schematic.
martyscncgarage wrote: Wed Dec 27, 2017 9:48 pm Image
I used the Acorn version first and it would not run right. I called DMM and they said there is too much noise transfer wiring it like the ACORN schematic. It has something to do with the 5vdc internal supply on the drive. I added a dual voltage supply and it works great.
Now onto the C Axis!
Clay
Clay
near Winston-Salem, NC
frijoli wrote: Sun Jan 07, 2018 7:20 pm DMM servos on DYN4 drives. First motion!
Clay
Clay, what you are saying is you ultimately wired it like this schematic?(This is DMM's schematic) Reason I ask is I am going to start laying out 3 DYN4 drives tomorrow and plan on wiring it this way.
frijoli
Post by frijoli »
Marty, Yes the schematic you showed me is also the schematic DMM sent me, and it works.
The original schematic in the Acorn "bundle" shows using the 5vdc internal power supply of the drive. That version did not work for me.
One caveat; I didn't connect the alarm yet.
Clay
Clay
frijoli wrote: Sun Jan 07, 2018 8:47 pm Marty, Yes the schematic you showed me is also the schematic DMM sent me, and it works.
Clay
Centroid is in the process of updating the DMM DYN2 and DYN4 schematics....
Good to hear you are getting closer....
frijoli
Post by frijoli »
martyscncgarage wrote: Sun Jan 07, 2018 8:49 pm
Clay
Pretty happy with this weekend. I wish there was a big Holiday now so I can finish.
Clay
DMM has informed us about using an external supplies for the DYN2/4 drive as well.
Noise was sited as well as the possible elimination of the on-drive logic power supply in future DYN2/4 units.
We will be updating the Acorn to DYN2/4 to use an external supplies soon. I'll post them here when they are done.
frijoli
Post by frijoli »
Steady as she goes. I do a little, then test, do a little...
I wish I had two weeks off work. I could finish this whole project. As it is I get about 4 hours on the weekends when I am not traveling.
Clay
frijoli wrote: Sun Jan 14, 2018 7:24 pm Steady as she goes. I do a little, then test, do a little...
WOW! Impressive! I hope you haven't forgotten anything! :shock:
frijoli
Post by frijoli »
martyscncgarage wrote: Sun Jan 14, 2018 8:00 pm
LOL, I never built a panel before and I only know what I see my guys doing at work. I just did that...
Clay
i posted on another thread..but seems like a good idea to post them here as well.
Acorn to dyn4 and dyn2 draft schematics.
Acorn_DYN2_DB25_S14828draft.pdf
(67.83 KiB) Downloaded 99 times
Acorn_DYN4_draft.pdf
(73.49 KiB) Downloaded 88 times
