Enable outputs on Acorn
kman1967
Post by kman1967 »
I am using a DB25 interface for my stepper motor outputs. While using this are the enable outputs on H2 and H3 still active to use?
If so are the active high or low for enabled?
Centroid_Tech2
Re: Enable outputs on Acorn
Post by Centroid_Tech2 »
When selecting the D25 connections in the wizard the behavior of the "Enable" terminals on H2 and H3 are inverted since most stepper drives are enabled by default and need a signal to disable them.Therefore these outputs are pulled low when the axis is NOT enabled. This behavior can be changed in the Advanced Axis Configuration menu.
kman1967 wrote: Thu Apr 25, 2024 8:05 am I am using a DB25 interface for my stepper motor outputs. While using this are the enable outputs on H2 and H3 still active to use?
Please tell us what stepper drive you are using, most stepper drives are enabled by default and the ENA connection is not needed.
kman1967
Post by kman1967 »
Thanks guys. That's the info I need. Although the drives are enabled by default, I am looking to disable them when required.
Gary Campbell
Post by Gary Campbell »
Can you explain when that would be?
If you disable drives on an Acorn, you will have to re-home everytime you re-enable the drives. Acorn is an open-loop system.
Yes, what he's talking about doing makes no sense at all. Hopefully he'll elaborate on the "why".
kman1967
Post by kman1967 »
This machine is in our R&D department. As part of the hazard assessment, one of the requirements is the disabling of the drives. It a requirement stipulated by our safety team which I don't have much say in. Honestly, I have found over time it's best just to do than to argue, less headaches.
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
If you have a properly configured E-Stop, this will already do the job or am I missing something?
Hope this helps
Nigel
I agree with Nigelo. Foremost, your emergency stop circuit should remove power from the stepper drivers. That should reliably ensure that the motors are free of power and torque whenever emergency stop is pressed.
