I posted last week with this issue. I also posted the report to go along with this last week when asked.
Encoder is only registering 325 max in the software and is actually running 2000 rpm.
Encoder bad?
I ordered a replacement encoder ?
Thoughts?
Encoder Issue
- CNC Control System Serial Number: E8EB1128AAC4-0405180824
Re: Encoder Issue
Could be a bad encoder. Could be a slipping coupling. Could be a bad electrical connection. Could be a bad power supply. Could be a bad encoder port.
Re: Encoder Issue
need a lot more information to help out.
Re: Encoder Issue
