Hello,
Is the wiring for Auto squaring, using ClearPath SDSK motors (jumper between Master & Slave) any different than the previous Acorn board?
Bill
Auto square wiring using ClearPath motors on AcornSix
Re: Auto square wiring using ClearPath motors on AcornSix
There is no jumper involved. Your 4th motor drive channel will simply be slaved to either the 1st or 2nd in the Config Wizard page
No the Auto-squaring enable jumper isn't necessary with the AcornSix board as the enable signals are handled slightly different than on the Acorn.
You can follow schematic s15145 for connecting ClearPath motors to AcornSix.
http://192.168.0.238/schematics/uploads/S15145.r2.pdf
@centroid_tech2 I think you will need to put a public URL there for forum users to access
click.
https://www.centroidcnc.com/centroid_di ... browse.php#
type in the search bar "acornsix" to see all acornsix schematics
type in acornsix clearpath to see clearpath schematic
or type in the schematic number
