encoder suitability
encoder suitability
could anybody please confirm if this encoder will be suitable? eBay item number:172623609462
OMRON Rotary Encoder Incremental E6B2-CWZ6C
Re: encoder suitability
I'm not an encoder expert by any means but when I plugged that number in out of curiosity, it didn't come up as an encoder. Maybe try again?
Milton in Collierville, TN
yeah..just make sure you get the higher count one..they make this same part number in many different ppr (line )
its nice to have a 2000 line encoder on spindle which results in 8000 counts per rev.
I see omron makes a 1200 ppr version of this encoder which would yield 4800 counts per rev. see if they make one higher.
Automation direct has some one sale for $65. https://www.automationdirect.com/adc/Se ... 22000.0%22
Keith, the ebay item i've quoted does say its a 2000 pr encoder, I'm quite confused with these encoder figures! Here's the specs:
Material:ABS+Aluminum
Shaft Material: SUS420J2
Supply Voltage: DC 5V-5%~24V+15% Pulse(p-p) less than 5%
Current : less than 70mA.
Output phases: A, B, Z (reversible)
Resolution (Pulse / rotation):10 20 30 40 50 60 100 200 300 360 400 500 600 720 800 1000 1024 1200 1500 1800 2000
Starting torque:<0.98mN.m
Maximum speed:6000r/min
Operating temperature:-10-70 centigrade
Store temperature:-25-85 centigrade
I just ordered the OMRON Rotary Encoder E6B2-CWZ1X 2000P/R E6B2CWZ1X on Ebay.
Looking at the documentation of the encoder, I don't see a reason why it should not work, and for only 26 USD I am willing to try this encoder.
hmm that has a slightly different model number to the one i've seen on ebay (as above) wonder what the difference is?
The difference is the output phases. the one I ordered has A A/ B B/ Z Z/ just as mentioned in the documentation of Centroid.
could you send the ebay link please?
Could one of the centroid chaps confirm if this is a suitable encoder please?
- q085_e6b2-c_incremental_rotary_encoder_40_mm_datasheet_en.pdf
- (257.82 KiB) Downloaded 137 times
